PIX515e and ASDM
If I upgrade my PIX515e to 7.x can I run ASDM on it?
TIA,
Gary
Silver
Re: PIX515e and ASDM
Yes. ASDM is the replacement for PDM in code ver 7.
Thank you very much!
Bronze
Hello Gary,
Yes, depending on the IOS version, you will have to have the compatible ASDM version running on your PIX,
IOS --- ASDM
7.0 --- 5.0
7.1 --- 5.1
7.2 --- 5.2
There is not compatibilty issue between different releases, however it always recommended to have the latest release for each IOS and ASDM...
Moreover, once you load ASDM on your PIX, you need to activate it through the following commands:
asdm image flash:/asdm501.bin
where asdm501.bin is an example of an ASDM file you have loaded to your pix
you also need to enable HTTPS server on the device through the following command:
http server enable
you also need to specify the hosts (IP's) who are allowed to https into the device, using the following command:
http 10.1.1.1 255.255.255.255 inside
where IP address 10.1.1.1 is a host that can access ASDM and which is connected via the inside interface. You can also allow an entire subnet to access it - your choice!
Now you can verify the connection by typeing in your browser the following:
https://10.1.1.254
or
https://10.1.1.254/admin/
where 10.1.1.254 is the IP on the inside interface - I believe in your case it will be different...
I hope this is useful, please rate if it is...
Thanks and regards,
Osama
Thanks very much! Your help is greatly appreciated.
366
