PIX515e and Netmeeting
I need the correct syntax to configure ip 67.117.78.183 to pass the Netmeeting protocol. Does anyone know the syntax and port for this protocol?
TIA,
Gary
Re: PIX515e and Netmeeting
Hi Gary,
To establish outbound NetMeeting connections through a firewall, the firewall must be configured to do the following:
- Pass through primary TCP connections on ports 389, 522, 1503, 1720, and 1731.
- Pass through secondary TCP and UDP connections on dynamically assigned ports (1024-65535).
Port------------Function
TCP-389---------Internet Locator Service (ILS)
TCP-522---------User Location Service
TCP-1503--------T.120
TCP-1720--------H.323 call setup
TCP-1731--------Audio call control
TCP-Dynamic-----H.323 call control
UDP-Dynamic-----H.323 streaming Real-Time Transfer Protocol (RTP)
The following ACL example is used to allow outside user to establish netmeeting connection to internal host that mapped to Public ip of xx.xx.xx.xx
Example:
access-list outside permit tcp any host xx.xx.xx.xx eq 389
access-list outside permit tcp any host xx.xx.xx.xx eq 522
access-list outside permit tcp any host xx.xx.xx.xx eq 1503
access-list outside permit tcp any host xx.xx.xx.xx eq 1720
access-list outside permit tcp any host xx.xx.xx.xx eq 1731
access-list outside permit udp any host xx.xx.xx.xx range 1024 65535
access-group outside in interface outside
static (inside,outside) xx.xx.xx.xx aa.aa.aa.aa netmask 255.255.255.255 -> map your internal host IP to public IP. ***
If you have ACL applied on your firewall-inside interface and need to allow internal host to establish netmeeting session on the outside/internet, the ACL will be similar, except change the xx.xx.xx.xx IP to real internal host ip and static map *** is not required. Apply the ACL on the firewall-inside interface.
More details is available at:
http://www.microsoft.com/windows/NetMeeting/Corp/reskit/Chapter4/default.asp#three
http://www.microsoft.com/technet/prodtechnol/netmting/reskit/netmtg3/part2/chapter4.mspx
Rgds,
AK
Wouldn't the h323 fixup handle most of this?
105
