PIX515E Failover
Hi!
I am configuring a PIX515E Failover bundle loading with IOS version 6.1(4). The primary unit functions well letting inbound and outbound traffic go through according to the configuration of the access-list. When I disconnect a cable or turn off the primary unit, the failover takes over and its configuration is excatly the same as the primary unit (which is normal). However, no traffic can go beyond the the firewall's own interfaces. Ping does not get any reply from the Dell PowerConnect 3024 switch directly connected to the firewalls. I would appreciate it if anyone could give me some tips on how to solve this failover problem. Thanks.
Lucien . Bercy
Re: PIX515E Failover
Hi Lucien,
Just wondering if "clear arp" or "clear xlate" helps get the traffic passing again?
yatin
Anonymous
N/A
Thanks, but "clear arp" or "clear xlate" doesn't help any.
Here is my config, if this can help you better. Don't worry about the IP addresses 'cause this Laboratory if for training purposes only and is entirely isolated from the Internet.
PIX Version 6.1(4)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname Neptune
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list acl_out permit icmp any any echo-reply
access-list acl_out permit tcp any any
access-list acl_out permit ip any any
access-list acl_out permit udp any any
pager lines 24
logging buffered debugging
interface ethernet0 100basetx
interface ethernet1 100basetx
mtu outside 1500
mtu inside 1500
ip address outside 192.168.5.1 255.255.255.0
ip address inside 172.16.8.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 192.168.5.4
failover ip address inside 172.16.8.3
pdm history enable
arp timeout 14400
global (outside) 1 192.168.5.5-192.168.5.253 netmask 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 192.168.5.254 172.16.3.3 netmask 255.255.255.255 0 0
access-group acl_out in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.5.2 1
route inside 172.16.3.0 255.255.255.0 172.16.8.2 1
timeout xlate 0:30:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:7af6813f4d75d98f77920d6e45f9378b
91
