PIX515E Help!!!! Inside to DMZ
Hi all, I hope someone can help me. I'm totally new to the PIX and I cant seem to get my inside network to see my web servers on my DMZ. I've attached my config file. Any advice would be a great help!
Re: PIX515E Help!!!! Inside to DMZ
You do not have a nat for your inside hosts accessing the DMZ.
nat (inside) 10 0.0.0.0 0.0.0.0 0 0
would need
global (dmz) 10 interface
You dont really need this:
static (dmz,inside) 172.16.5.4 172.16.1.4 netmask 255.255.255.255 0 0
static (dmz,inside) 172.16.5.5 172.16.1.5 netmask 255.255.255.255 0 0
static (dmz,inside) 172.16.5.6 172.16.1.6 netmask 255.255.255.255 0 0
static (dmz,inside) 172.16.5.7 172.16.1.7 netmask 255.255.255.255 0 0
static (dmz,inside) 172.16.5.8 172.16.1.8 netmask 255.255.255.255 0 0
Awesome! Thanx I'll try it tonight!!!
Hello Jason,
How are you trying to reach them, are you using the internal ip address 172.16.5.x address, domain name?
try browsing them using the internal ip.
I can see then with the 172.16.1 address but not with the outside address
Hi There Did you solve this problem?.... I do have similer probmlem connecting from Inside to DMZ..............
Actually u dont even need to NAT at all..
U can remove the static nat and also the nat 10
U can do a nat exempt
Just say
access-list nonat permit ip 172.16.5.0 255.255.255.0 172.16.1.0 255.255.255.0
nat (inside) 0 access-list nonat
I think that should take care of your problems.
I am assuming int his case that the session is being initiated from inside interface to DMZ.
Thanx I'll give it a try
Hello Jason,
If you wanted to reach them using the public ip then you should use a static command destination nat.
static (dmz,inside) 24.249.123.36 172.16.1.5 netmask 255.255.255.255 0 0
Using this static command, you should be able to reach them browsing by ip.
you are the man!!!!!!!!! Thank you so much it worked great. If you're ever in VA I owe you a beer!!!!
104
