Pix515E: inside Can't reach DMZ host , please help
Thank all those who have helped me solve provious problems, This time I got one more: from an inside host , say 10.1.1.5(mask 255.255.255.0,gateway 10.1.1.254), can not reach a DMZ host, say 30.30.30.51, even I can ping the DMZ host's public ip (70.183.141.200), please help. ( an abbr. configuration here):
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz2 security50
name 209.96.249.10 visinet-su-pc
name 10.1.1.10 paris
name 206.246.202.21 transact.option.net
name 10.1.1.206 corrie-pc
name 206.246.194.29 mail.visi.net
name 10.1.1.77 ed-pc
name 10.1.1.80 ed-wireless
object-group network full-outside-access
network-object host paris
network-object ed-wireless 255.255.255.255
object-group service mail-dns-tcp tcp
port-object eq ssh
port-object eq pop3
port-object eq smtp
object-group service ntp-udp udp
port-object eq domain
port-object eq ntp
object-group service sqlserver-ports tcp
description for sqlserver
port-object range 888 888
port-object range 1433 1433
object-group service mail-only tcp
port-object eq pop3
port-object eq smtp
access-list inside_access_in permit icmp 10.1.1.0 255.255.255.0 any echo
access-list inside_access_in permit udp 10.1.1.0 255.255.255.0 any object-group ntp-udp
access-list inside_access_in permit tcp 10.1.1.0 255.255.255.0 any eq domain
access-list inside_access_in permit tcp 10.1.1.0 255.255.255.0 host mail.cnfei.com object-group mail-only
access-list inside_access_in permit tcp 10.1.1.0 255.255.255.0 host mail.visi.net object-group mail-only
access-list inside_access_in permit icmp 10.1.1.0 255.255.255.0 30.30.30.0 255.255.255.0
access-list inside_access_in deny tcp 10.1.1.0 255.255.255.0 any object-group mail-only
access-list inside_access_in permit ip object-group full-outside-access any
access-list outside_access_in permit icmp any host 70.183.141.200
access-list outside_access_in permit icmp any any echo
access-list outside_access_in permit icmp any any echo-reply
access-list outside_access_in permit tcp any host 70.183.141.197 object-group sqlserver-ports
access-list outside_access_in permit tcp any host 70.183.141.198 eq 8190
access-list outside_access_in permit tcp any host 70.183.141.196 eq www
access-list outside_access_in permit tcp any host 70.183.141.196 eq 8109
access-list outside_access_in permit tcp any host 70.183.141.195 eq 4447
access-list outside_access_in permit tcp any host 70.183.141.202
access-list outside_access_in remark for su in visinet
access-list outside_access_in permit tcp host visinet-su-pc host 70.183.141.199
access-list outside_access_in permit tcp host transact.option.net host 70.183.141.194 eq www
access-list outside_access_in deny ip any any
ip address outside 70.169.138.132 255.255.255.0
ip address inside 10.1.1.254 255.255.255.0
ip address dmz2 30.30.30.30 255.255.255.0
global (outside) 10 interface
global (dmz2) 10 interface
nat (inside) 10 10.1.1.0 255.255.255.0 0 0
static (inside,outside) 70.183.141.194 cfserver netmask 255.255.255.255 0 0
static (inside,outside) 70.183.141.195 oscar netmask 255.255.255.255 0 0
static (inside,outside) 70.183.141.196 internal netmask 255.255.255.255 0 0
static (inside,outside) 70.183.141.202 10.1.1.239 netmask 255.255.255.255 0 0
static (inside,outside) 70.183.141.197 fifa netmask 255.255.255.255 0 0
static (inside,outside) 70.183.141.198 sugar netmask 255.255.255.255 0 0
static (inside,outside) 70.183.141.199 paris netmask 255.255.255.255 0 0
static (dmz2,outside) 70.183.141.200 30.30.30.51 netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 70.169.138.1 1
: end
any suggestions are greatly appreciated.
sean
Re: Pix515E: inside Can't reach DMZ host , please help
Hi suggest.
1.- nat (inside) 0 access-list inside_out_nat0
access-list inside_out_nat0 permit ip 10.1.1.0 255.255.255.0 30.30.30.0 255.255.255.0
2.- Add the below entry on your inside_access_in
This should give you access to the DMZ hosts when traffic is initiated from the inside.
I hope it helps .. please rate it if it does !!!
Thank you very much, fernando,
Yes, The IP works!!! there is a small problem though: I still can't ping from: 10.1.1.5(inside private IP) to 30.30.30.51( DMZ private IP), even I can reach tcp ports from inside host to DMZ host. I have a line to allow ICMP, but still can't ping, please help:
(I can ping 30.30.30.51 using its public IP, there is no firewall on the host to block any traffic).
Thanks.
Have you tried applying an access-list to the dmz interface? or a static from dmz2 to inside?
115
