PIX515E Interface Problem?
I have a PIX515E, I have installed 2 PIX-1FE cards in the two slots, but only one PIX-1FE is working not the 2nd one means total 3 FE. Here is the output of show ver command.
Cisco PIX Firewall Version 6.3(4)
Cisco PIX Device Manager Version 3.0(2)
Compiled on Fri 02-Jul-04 00:07 by morlee
xxxxxxx up 4 hours 24 mins
Hardware: PIX-515E, 64 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: ethernet0: address is 0014.69e9.5731, irq 10
1: ethernet1: address is 0014.69e9.5732, irq 11
2: ethernet2: address is 000e.0ca2.8502, irq 5
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Physical Interfaces: 3
Maximum Interfaces: 5
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has a Restricted (R) license.
So kindly tell me to use the 2nd PIX-1FE in 2nd slot, May I have to upgrade the IOS version or only one PCI card is supported at a time.
1 REPLY
Gold
Re: PIX515E Interface Problem?
With restricted licence you can have max three 10/100 interfaces.... So you need upgrade to unrestricted if you want to use 4 interfaces
M.
Hope that helps, rate if it does
93
