PIX515E Telnet from Outside
i don't arrive to connect at PIX515 with command telnet on interface Outside 192.168.0.4 from Cisco 831 '192.168.0.253'.
Internet---C831----------PIX515------LAN
192.168.0.253 168.0.4 10.0.0.11 0.1
When i am inside 'LAN 10.0.0.1' i have not problem to connect at PIX.
On C831 the ping to 192.168.0.4 is ok.
But Telnet
maison#telnet 192.168.0.4
Trying 192.168.0.4 ...
% Connection timed out; remote host not responding
Please, help me.
Best regards,
Fabrice.
Green
Re: PIX515E Telnet from Outside
Pix doesn't allow telnet to outside interface, only ssh.
Thank you for reply, but i don't make this.
How do you configure this SSH on the Outside interface PIX ?
How do you enable SSH (aaa) on the PIX515 ?
And after is it possible from my C831 to access to PIX with SSH ?
i tried but i don't message error :
maison#ssh 192.168.0.4
I tried with Putty SSH from my pc to interface inside PIX but it doesn't work too.
Best regards,
I found to connect in SSH from client pc to if_inside PIX.
i don't found for Outside from C831, i tape this command line:
ssh -c 3des -l pix -v 1 192.168.0.4
but it doesn't work, can you help me please ?
Do you have a line stating :
ssh outside
or
telnet outside
in the pix's config ?
jF
Yes, it's correct, in the pix.
Fab
Try this
aonnect from internal network and use the command "passwd" to create a telnet password. This will also enable the telnet from outside
hope this works
regards
Boonlia Prince Komal
is it possible to connect with telnet session form outside ?
because i have created a password and i have enabled the telnet from outside but it doesn't work ?
only work from inside with my Putty client with telnet and ssh.
On c831, i try to make same think but it doesn,' work too.
What is the line to authorize telnet or ssh access from outside ?
jF
540
