12-22-2003 03:13 PM - edited 03-09-2019 05:57 AM
I am experimencing a problem relating to static NAT maximum connection in PIX520. For the following example configuration:
static (inside,outside) 202.96.128.10 196.16.20.9 netmask 255.255.255.255 50 50
The maximum tcp and udp connection should be limited to 50. But it doesn't seem to be the case. 196.16.20.9 is a W2K DNS server, the normal DNS queries are about 10 udp connections so maximum 50 is more than enough. But if the outside Internet connection is down, DNS queries will increase to 200,000 udp connections in a single second (large enterprise enviroment) as it doesn't get a single reply and just keep trying, refreshing cache, etc. In such a senario, no more Internet traffic can pass through.
I am wondering why the connection is not limited by the static nat maximum connection.
Thanks a lot
Frank
12-23-2003 05:39 AM
Frank,
Out of curiosity, which version of code do you currently have on your PIX? The symptoms you describe with the DNS conns sounds a lot like a known issue and I just want to make sure of your current code level before making a recommendation. Let me know when you have a second.
Scott
12-23-2003 02:26 PM
Thanks scott. The version is 6.3(3).
Cheers.
Frank.
12-23-2003 08:44 PM
Thanks Frank. Kinda what I was expecting. I think this smells like CSCec45748. My recommendation would be to open a TAC case and request the latest 6.3(3) interim image to test with. I have had a few other customer run into this problem. Let me know if this helps.
Scott
