PIX535-VPN3000 LAN-TO-LAN
We are using PIX535 as HUB VPN Gateway.
and PIX535 has VPN Tunnels with 10 VPN3000s.
The Problem is as follow:
We have servers(10.10.1.0/24) inside PIX535.
After connecting Lan-To-Lan, the remote user behind the VPN3000 can't connect the only one server(10.10.1.13) but the other servers is okay.
The only different thing is the server(10.10.1.13) has windows 2003 as OS.
Do anyone know about this problem ?
Re: PIX535-VPN3000 LAN-TO-LAN
Are you filtering any ports in the concentrators?
Are you filtering ports in the vpn access list on the pix for your crypto map for that server?
Did it work before you put the firewall in place?
I found the source of problem.
The problem is relating to PIX535's config.
Thank'you for your attention.
94
