Please help Identify Firewall Pix515E-UR
I ordered PIX515E-UR and my vendor delivered a firewall that is labelled PIX515E. But the box is labelled PIX515E-UR. My question is whether PIX515E-UR is labelled as PIX515E or PIX515E-UR on the part. Is there anyway definite way to distinguish them?
1 REPLY
Re: Please help Identify Firewall Pix515E-UR
The chassis is the same for both. The UR bundle has extra RAM, it also has a difference license that allows you run failover on the pix. You can check the RAM and the extra features by doing a "show ver" on the pix.
You can check the following link for the differences between the Restricted and Unrestricted bundles:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_data_sheet09186a0080091b15.html
Hope this helps,
-Nairi
88
