Please help on SOHO 91
I have recently been trying set up a site-to-site connectction, using a Cisco SOHO 91 to an Intel NetStructure VPN Gateway, using IPSec/Isakmp.
As you all can figure, it doesn't work, otherwise I didn't have to post this :-)
In the debug of the SOHO, it seems like everything is working smoothly, until I get this output:
19:07:26: ISAKMP (0:2): Send initial contact
19:07:26: ISAKMP (0:2): SA is doing pre-shared key authentication using id type
ID_IPV4_ADDR
19:07:26: ISAKMP (2): ID payload
next-payload : 8
type : 1
addr : x.x.x.x
protocol : 17
port : 0
length : 8
19:07:26: ISAKMP (2): Total payload length: 12
19:07:26: CryptoEngine0: generate hmac context for conn id 2
19:07:26: ISAKMP (0:2): sending packet to y.y.y.y my_port 500 peer_port 50
0 (I) MM_KEY_EXCH
19:07:26: ISAKMP (0:2): Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
19:07:26: ISAKMP (0:2): Old State = IKE_I_MM4 New State = IKE_I_MM5
19:07:26: ISAKMP (0:2): received packet from y.y.y.y dport 500 sport 500 (
I) MM_KEY_EXCH
19:07:26: ISAKMP: set new node 1574635723 to QM_IDLE
19:07:26: ISAKMP (0:2): processing HASH payload. message ID = 1574635723
19:07:26: ISAKMP (0:2): processing NOTIFY INVALID_ID_INFO protocol 1
spi 0, message ID = 1574635723, sa = 810D739C
19:07:26: ISAKMP (0:2): peer does not do paranoid keepalives.
19:07:26: ISAKMP (0:2): deleting SA reason "recevied fatal informational" state
(I) MM_KEY_EXCH (peer y.y.y.y) input queue 0
19:07:26: ISAKMP (0:2): deleting node 1574635723 error FALSE reason "information
al (in) state 1"
The ID Payload says Protocol 17, port 0. I think that's what causes the messages about not doing "paranoid keepalives" and "fatal informational"
Anyway, I can't get the VPN to work.
I have tried to lower the encryption. I have tried 3des and des (the Intel NetStructure does not support other than des and 3des). I have tried hash md5 and sha, Ihave tried tunnel and transport mode.
There are one firewall along the way, but it is configured to pass through 500/udp and protocol 50. As far as I can see, there is nothing that should block the communication.
I don't think the communication is blocked either, but the ID payload is comuted wrongly.
Does any of you out there have a clue to the problem?
Does the SOHO 91 support such VPN configuration?
Any suggestion is appreciated.
186
