please help.....PIX515 / 7.1 with 4 networks setup
Hi all,
now I've tried to get this config working for nearly 2 weeks and it is really starting to get to me. I would very much appreciate someone pointing me in the right direction.
I have 4 networks on my 515;
Outside - Security Level 0 (88.96.164.72)
Inside - Security Level 100 (10.0.1.0/24)
VM - Security Level 99 (10.0.2.0/24)
DMZ - Security Level 50 (172.16.1.0/24)
With regards to ACL's I need to be able to;
Allow all traffic from Inside to VM
Allow all traffic from VM to Inside
Allow DNS from Outside to VM
Allow SMTP from Outside to VM
Allow DNS from Outside to DMZ
Allow SMTP from Outside to DMZ
Allow SMTP from DMZ to Inside
I need to NAT all Inside and VM to the IP of the Outside I/F outbound.
I need to NAT mailhost in DMZ to 88.96.164.72 so outside can access via Public IP
I need to NAT dnshost in DMZ to 88.96.164.73 so outside can access via Public IP
Inside & VM hosts appear on DMZ with their own addresses
DMZ hosts appear on Inside & VM with their own addresses
Silver
Re: please help.....PIX515 / 7.1 with 4 networks setup
can you post a "sanitized" copy of your current config?
Chicco,
For you acls, doesnt you DNS server need to make the requests outbound and not the reverse.
On your acl that is applied to the outside interface, create the acls for the following.
On the acl that is applied to the DMZ interface, create the acls for:
On the acl that is applied to the VM interface, create the acls for:
The nats for the inside and VM use the nat and global commands.
Use static translations for the mail and dns hosts.
Use nat 0 for the inside and vm to the dmz.
Nothing needed for dmz to inside and VM.
Silver
Try using this sample config...
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 88.96.164.72 255.255.255.0
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 10.0.1.0 255.255.255.0
interface GigabitEthernet0/2
nameif VM
security-level 99
ip address 10.2.0.0 255.255.255.0
nameif DMZ
security-level 50
ip address 172.16.1.0 255.255.255.0
nat (inside) 1 10.0.1.0 255.255.255.0
nat (vm) 1 10.0.2.0 255.255.255.0
global (outside) 1 interface
static (DMZ,Outside) 88.96.164.72 172.16.1.X
static (DMZ,Outside) 88.96.164.73 172.16.1.X
static (inside,DMZ) 10.0.1.0 10.0.1.0 netmask 255.255.255.0
static (VM,DMZ) 10.0.2.0 10.0.2.0 netmask 255.255.255.0
static (DMZ,Inside) 172.16.1.0 172.16.1.0 netmask 255.255.255.0 (not necessarily needed)
static (VM,Inside) 10.0.2.0 10.0.2.0 netmask 255.255.255.0 (not necessarily needed)
access-list inside_in extended permit ip any 10.0.2.0 255.255.255.0
access-list vm_in extended permit ip any 10.0.1.0 255.255.255.0 (this is not advisable.....)
access-group inside_in in interface inside
access-group vm_in in interface vm
The following cannot be done as said...
Would you like the traffic to just go to specific DNS or Mail Servers (for instance the two static translations setup)?
I can help with the rest if you clarify which IPs need connections to them on the vm,dmz and inside. Hope this helps. If it is helpful, please rate me.
Cheers.
Jay Walker
Firstly I just want to thank you all for your input.
Just to clarify things. The inside network as you have guessed is a LAN range that my end users are sitting on. The VM network is a LAN range that my ESX Virtual Machines sit on. As I have DC's, Exchange, Sharepoint sitting in this rather than configuring individual acl's it's easier just to allow all traffic from inside to VM and vice versa.
On looking into the config a bit further I've realised as the pix is stateful I do not need the acl's for SMTP from Outside to VM or DNS from Outside to VM. These will come from the internal DNS and SMTP servers and go outside.
Jay, I would like traffic to go to specific DNS and Mail Servers as I will be hosting 1 of my own DNS servers and 1 front-end sendmail box, these should go to the static translations.
At some point however I will be hosting a front-end Exchange cluster in the DMZ that needs to talk to the back-end cluster in the VM. This will be segregated further by an ISA firewall for RPC inspection.
I'm afraid the above config has not worked. After applying it I cannot browse the Internet or DNS lookup from inside, cannot connect to anything in the VM network.
Even without any rules and just the implicits I cannot browse the Internet or do DNS lookups from the VM network either. Surely that is wrong as I can from the inside network.
Chicco,
Can you please post a sanatized copy of your config?
Hi mgaysek.
Below is copy of my config. The weird thing is that I am able to ping hosts on the vm from inside and vice versa yet I can't do anything else. For example I have a test IIS server running on 10.0.2.15 and yet when I try to browse it times out. The syslog says;
Aug 21 2006 22:19:25 106015: Deny TCP (no connection) from 10.0.1.51/3952 to 10.0.2.15/80 flags RST on interface inside
PIX Version 7.1(1)
names
interface Ethernet0
nameif outside
security-level 0
ip address 8X.XXX.XXX.72 255.255.255.248
interface Ethernet1
nameif inside
security-level 100
ip address 10.0.1.251 255.255.255.0
interface Ethernet2
shutdown
no nameif
security-level 99
no ip address
<--- More --->
shutdown
no nameif
security-level 90
no ip address
interface Ethernet4
nameif dmz
security-level 50
no ip address
interface Ethernet5
nameif vm
security-level 90
ip address 10.0.2.251 255.255.255.0
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
mtu vm 1500
mtu dmz 1500
no failover
arp timeout 14400
nat-control
nat (inside) 1 0.0.0.0 0.0.0.0
nat (vm) 1 0.0.0.0 0.0.0.0
static (inside,vm) 10.0.1.0 10.0.1.0 netmask 255.255.255.0
static (vm,inside) 10.0.2.0 10.0.2.0 netmask 255.255.255.0
route outside 0.0.0.0 0.0.0.0 8X.XXX.XXX.73 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
: end
pixfirewall(config)#
Chicco,
Get rid of both your static statements.
Put in
global(vm) 1 interface
just as a test.
You will need to do a clear xlate before testing.
In addition you do not need the access list applied to you inside interface, unless you want to restrict traffic leaving the inside interface.
Try this and let me know how you make out.
Thanks mgaysek, I will give this a try tonight.
Silver
Can you make a modified list of what you would like the firewall to do? I will redo the config from last week to reflect the changes... Thanks.
Hey.
I've not had time to do the above change yet.
jwalker.
Inside and VM are both trused networks, they are my two internal networks so I would like all traffic to flow between them without restrictions. DMZ will host a DNS and a mail server.
Essentially what I need to do is;
Allow all traffic from inside to vm
Allow all traffic from vm to inside
Allow all traffic from inside to outside
Allow all traffic from vm to outside
Allow DNS traffic into DMZ (specific host)
Allow SMTP traffic into DMZ (specific host)
Hey all.
Sorry I've been away on vacation. Any chance of someone doing a config for me pls, still have issues! :)
Chicco
Silver
Post your current config and I will revise based on your requirements...
Jay
Hi.
I currently have the PIX in a very basic config and yet I am still having issues. For the time being I have only configured inside, VM, and outside.
Yet from the VM network I cannot browse to the Internet. I only have the default acl on there (any, any, interface (vm - outbound), IP).
I get the error "10001: No route to 10.0.2.21 from 193.0.14.129"
This should surely work as 10.0.2.0/24 is directly connnected???
Here is my config and my show route;
PIX Version 7.1(1)
hostname corp-fw-01
domain-name xxxxxxxxxxxxxxxxx.com
enable password xxxxxxxxxxxxx encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address 83.xxx.xxx.93 255.255.255.240
interface Ethernet1
nameif inside
security-level 100
interface Ethernet2
shutdown
no nameif
security-level 99
no ip address
nameif dmz
security-level 50
no ip address
interface Ethernet5
nameif vm
security-level 90
passwd xxxxxxxxxxxx encrypted
ftp mode passive
clock timezone GMT/BST 0
clock summer-time GMT/BDT recurring last Sun Mar 1:00 last Sun Oct 2:00
dns server-group DefaultDNS
domain-name XxxxxxxxxxxxxX.com
pager lines 24
logging enable
no asdm history enable
arp timeout 14400
nat-control
route outside 0.0.0.0 0.0.0.0 83.xxx.xxx.94 1
http server enable
http 10.0.1.0 255.255.255.0 inside
no snmp-server location
dhcpd ping_timeout 50
dhcpd enable inside
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect pptp
inspect dns maximum-length 1000
Cryptochecksum:4208af3b5c14fd24f0df5f8ccabd8e72
: end
corp-fw-01(config)#
And a show route.
S 0.0.0.0 0.0.0.0 [1/0] via 83.xxx.xxx.93, outside
C 10.0.1.0 255.255.255.0 is directly connected, inside
C 10.0.2.0 255.255.255.0 is directly connected, vm
C 83.xxx.xxx.80 255.255.255.240 is directly connected, outside
Hey Chicco,
I do not see anything majorly wrong. You do not need this static translation: static (vm,inside) 10.0.2.0 10.0.2.0 netmask 255.255.255.0
Think of it as you are translation a site on the internet. You generally do not do that or need to.
Also, I do not see any acl's for your vm dmz. It has been a while since I have looked at this so I may have forgoton something.
What things are currently not working?
132
