please help...what does these following event means?
I have the following event log from my concentrator I am trying to create a L2L tunnel using ipsec. how to fix this? thanks in advance
2359 01/02/2006 13:56:29.370 SEV=4 IKE/41 RPT=456 x.x.x.x
IKE Initiator: New Phase 1, Intf 2, IKE Peer x.x.x.x
local Proxy Address y.y.y.y, remote Proxy Address x.x.x.x,
SA (L2L: manila-US)
2362 01/02/2006 13:56:29.660 SEV=5 IKEDBG/64 RPT=239 x.x.x.x
IKE Peer included IKE fragmentation capability flags:
Main Mode: True
Aggressive Mode: True
2364 01/02/2006 13:56:37.960 SEV=5 IKE/0 RPT=475 x.x.x.x
Received an un-encrypted Invalid Cookie notify message, dropping
2365 01/02/2006 13:56:37.960 SEV=4 IKE/0 RPT=476 x.x.x.x
Information Exchange processing failed
Re: please help...what does these following event means?
maybe the following links can assist you:
http://www.cisco.com/en/US/products/sw/secursw/ps2300/products_configuration_guide_chapter09186a008007cf4a.html
What exactly are you trying to achieve, what is the involved hardware?
Martin
Hi Sir, thanks for the reply, I am trying to connect two vpn concentrators and the logs I have included are logs i saw on my concentrator trying to connect to another concentrator. I just want to create an IPSEC L2L tunnel between the two concentrator. Please help.
I am having the same issue with 2 3005 concentrators. I looked at the guide that was reference but that didn't seem to shed any light on the subject.
regards,
229
