08-18-2006 12:40 PM - edited 02-21-2020 01:07 AM
I need help with communication between two interfaces of PIX..
pls.
08-18-2006 12:43 PM
Pls share more detail with "sanitized" config.
08-18-2006 12:45 PM
What do you need to do? Give me some specs to work with... And are the interfaces already created? Answer these questions..
which devices need to communicate with devices on the other network.
which devices are on which interfaces
etc...
08-18-2006 01:09 PM
I have this configuration
nameif ethernet4 dmz2 security10
nameif ethernet5 dmz1 security5
access-list acl_dmz2 permit ip 10.26.6.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list outside_cryptomap_20 permit ip host 10.26.6.185 host 10.0.108.47
access-group acl_dmz1 in interface dmz1
route dmz2 10.0.108.47 255.255.255.255 10.0.106.1
crypto map outside_map 20 ipsec-isakmp
crypto map outside_map 20 match address outside_cryptomap_20
crypto map outside_map 20 set peer 10.0.106.1
crypto map outside_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map interface dmz2
But, when the communication between dmz2 to dmz1 the connection go through other interface.
08-18-2006 01:24 PM
Can you please send the entire config? If this is all you have, there are MANY things missing...
