Plz Help
I am having major problems that hopefully someone can help with
I am try to install Cisco CSA 5.0 onto a test server, I install VMS 2.3 then install CSA 5.0 the problem is that once I go into the VMS and try and go into Management Center > Security Agents V5.0 I get a Internal Server Error also in the Monitoring Center > Security Monitor.
When I log onto the server I see perl.exe alerts
HELP!!!!
  • Other Security Subjects
1 REPLY
Silver
Re: Plz Help
This could be a result of some recent MS patch that you have installed. Make sure you have the right version and all the patches applied on the OS before intalling the CSA.
79
