Policy changes on running VPN
Hello
We have end to end connectivity between two locations through IPSEC VPN and we have defined policies using access-list, we have make changes (adding new host access) in the access-list on the remote router and we are accessing remote router through telnet. When we are removing access-list for applying updated access-list we lose the connectivity because of the policy mismatch, is there any way to change the access-list without loosing the telnet access.
Please revert if any suggestion.
Yamin
1 REPLY
Re: Policy changes on running VPN
You can make changes to the access list by using the sequence numbers used by access list statements. Sequence numbers can be used to add/delete access control entries. This way you don't have to remove the access list to make any modifications.
Take a look at this example.
http://cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a0080716ebf.html#wp1027258
Sundar
88
