12-24-2005 03:56 AM - edited 03-09-2019 01:27 PM
Behind an vodsl-router I have a 871 and I want to configure the vodsl on port 80, but that's only possibe from the inside network. I'm not inside, that's why I want a port forwarding on the cisco to the vodsl-router. Is that possibe and how?
Situation:
internet <-> vodsl-router (193.173.97.153) <-> (wan: 193.173.97.158) cisco871 (lan: 192.168.14.1)
Best regards,
Alex Goudriaan
12-27-2005 02:44 PM
assuming you are from the internet. the traffic will hit the vodsl router before hitting the 871, just wondering how would the port forwarding on the 871 would help.
i guess you need to configure remote access on the vodsl router directly.
12-27-2005 11:57 PM
There's an addressblock, so I can directly through the la110 to the 871 which has a different address.
Then I need to the address of the la110, but that's only possible to the inside interface, and that's the whole problem. For now it's not possible to overtake a computer, because there isn't any. Just terminals.
