Community Member
port forwarding
I have a Pix 515 firewall. V5.0
Currently two seperate mail servers on the "DMZ" side of the firewall.
Internal IP: x.x.x.x
Outside IP: y.y.y.y
here is the setup
names x.x.x.10 mail1
x.x.x.26 mail2
Alias (inside) y.y.y.10 mail1 255.255.255.255
Alias (inside) y.y.y.26 mail2 255.255.255.255
Static (dmz,outside) y.y.y.10 mail1 netmask 255.255.255.255 0 0
Static (dmz,outside) y.y.y.26 mail2 netmask 255.255.255.255 0 0
conduit permit tcp y.y.y.10 eq smtp any
conduit permit tcp y.y.y.26 eq smtp any
My question/problem is I am going to incorporate a "smtp" virus filtering server to check port 25 incoming. I would like to place this on the dmz and filter mail traffic. The mail is then forwarded to the mail1 and mail2 server based on domain name. The smtp filter IP would be x.x.x.12
What statements do I need to change for this to work? Do I have to change MX records or just the firewall? I would like to change the firewall only.
Silver
Re: port forwarding
you would need to change your mx records - you would need to in order for all internet hosts to send it email before the other hosts.
Community Member
Re: port forwarding
Point your static at the new gateway.
Remove the extra static (or give the server a second ip.)
80
