port forwarding
I've got a Pix 506e V6.3. I've got a customer that needs port 3389 opened so that he can remote desktop his server. He wants to be able to type in the static outside IP address and it automaticlly point to the inside IP of the server which is 192.168.1.200 on port 3389. I use the PDM software quit abit but I'm not to familiar with using the command line. Could you please let me know what entries in the order that I would need to enter them to get this working?
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx
passwd xxxx
hostname pixfirewall
domain-name ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol smtp 1025
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list inside_access_in permit ip any any
access-list inside_access_in permit tcp any eq smtp any eq smtp
access-list outside_access_in permit tcp any eq smtp any eq smtp
access-list outside_access_in permit icmp any any
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 0.0.0.0 255.255.255.0 inside
pdm location 192.168.1.200 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.199 inside
dhcpd dns 192.168.1.200 64.193.208.81
dhcpd wins 192.168.1.200
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd domain familyabusecenter.org
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:xxxx
pixfirewall#
1 ACCEPTED SOLUTION
Re: port forwarding
I do not use the PDM but you can drag and drop the configlines in your CLI (command line interface).
Using the blue Cisco Cable with a Terminal Emulation as Hyperterminal or minicom using VT100 8/N/1 9600:
Note that lines with # in the beginnig are config remarks not commands.
Example for RDP - Teminal Services Microsoft to inside:
access-list outside_access_in line 1 permit tcp any interface outside eq 3389
# This will allow any host on the Internet to use RDP into RDPServer
static (inside,outside) tcp interface 3389 192.168.1.200 3389 netmask 255.255.255.255 0 0
#Port Redirect tcp port 3389 RDP to 192.168.1.200
Note: You could also use a DynDNS or No-IP Dynamic DNS Update Tool to use a dyn DNS with your Cisco PIX.
You need just to install the software on an internal PC. http://www.no-ip.com/downloads.php
sincerely
Patrick
Re: port forwarding
Here is my show run
PIX Version 6.3(5)
enable password IyEh5BPRQrzMfRR2 encrypted
passwd IyEh5BPRQrzMfRR2 encrypted
names
pager lines 24
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd enable inside
terminal width 80
Cryptochecksum:92d16b941048bafc7386258455a1b852
pixfirewall#
Re: port forwarding
sincerely
Patrick
Re: port forwarding
You might need to reset the Address Translation Table to activate the Port Redirection for RDP.
enable
conf t
clear xlate
Note that this will reset all connections !!!
sincerely
Patrick
Re: port forwarding
access-list acl_out permit tcp any host (outside) eq 3389
static (inside,outside) tcp (outside IP) 3389 (inside IP) 3389 netmask 255.25
5.255.255 0 0
261
