09-05-2003 12:18 PM - edited 03-09-2019 04:41 AM
I am having a problem with incoming port redirection. I have allowed Lotus Notes traffic to a server which resides on a different subnet than the PIX, but I can't connect to it. I set up port redirection to another server that is on the same subnet as the PIX with no problems. Is there something that I need to do, other than setting up routes, to make it work?
09-05-2003 12:50 PM
Just check if you have a "route" statement who targets to this subnet.
Ben
09-08-2003 07:27 AM
There is a route to this subnet. As I mentioned, there are 2 allowed inbound connections but only the one to the local subnet works. I'll include the relevant lines below:
ip address outside xxx.xxx.xxx.xxx 255.255.255.252
ip address inside 192.168.6.242 255.255.255.0
global (outside) 1 interface
access-list acl_out permit tcp any host xxx.xxx.xxx.xxx eq lotusnotes
access-list acl_out permit tcp any host xxx.xxx.xxx.xxx eq https
access-group acl_out in interface outside
static (inside,outside) tcp interface lotusnotes 192.168.4.158 lotusnotes netmask 255.255.255.255 0 0
static (inside,outside) tcp interface https 192.168.6.240 10000 netmask 255.255.255.255 0 0
route inside 192.168.4.0 255.255.255.0 192.168.6.150 2
09-08-2003 06:09 PM
Scott,
I don't think the problem is about the route but just to be sure, you can try:
- route inside 192.168.4.0 255.255.255.0 192.168.6.150 1
or
- route inside 192.168.4.0 255.255.255.0 192.168.6.242 1
The second route statement will force the PIX to send an ARP0 locally to find the destination on the first inside subnet. The router, if it's a Cisco one, should respond to this ARP (Proxy ARP feature), then the PIX will send packets to the right place.
If those variants of route don't work, you will have to enter in logging mode, debug level, to see what's happen.
Hope this help!
Ben
Quebec
09-16-2003 07:58 AM
I tried both of these options with no success. When I tried looking at the debugging information there is nothing showing up except traffic from the 192.168.6.0 network.
Something else that has emerged is that no other network except the one the PIX is on (inside) can directly access the internet. They can ping the PIX and access PDM, but not the internet. On the 192.168.6.0 network I can use WS_FTP with the firewall option configured to access external sites, but not from any other subnet.
One thing to note is that the PIX is not our default gateway. We use a proxy (Squid) to access the internet. Because the proxy was placed on the 192.168.6.0 network, I had't noticed the problem.
