port redirection
I want to do port redirection for my inside users(port no 8888) to web server in DMZ(port no 80).
Case 1:Inside user types in browser http://192.168.101.10:8888
Case 2: http://mywebserverurl:8888
Inside n/w 192.168.100.0 DMZ n/w 192.168.101.0
I have done the same for internet using static (inside,outside) tcp ... command.And it is working fine.
Silver
Re: port redirection
can you check if its 192.168.101.10 or 192.168.100.10 in the following statement?
if your statement is correct then try using following statement:
static (dmz,inside) tcp 192.168.101.10 8888 192.168.101.10 80 netmask 255.255.255.255
You can use the static command or the alias command to do port redirection on the ASA. However the one suggested by singhsaju is the better/new way to do it.
Farrukh
349
