Portal Customization storage location and replication on ASA 5540 SSL VPN
When you customize a clientless VPN portal, it allows you to customize graphics and other elements. Where on the system are these stored? A sh flash command reveals nothing. I want to ensure that the customized elements are saved and are being replicated to the standby host. This is for 8.0(2)
1 REPLY
Silver
Re: Portal Customization storage location and replication on ASA
By default they are stored in running configuration, but you can export them as templates.
The customization you run on your webvpn portal can be exported/imported in ASDM, under:
'Configuration --> RAS VPN --> Clientless VPN --> Portal ---> Customization'
119
