Power consuption
Need some details, Approx Power utilizsed br Router and Switches
Re: Power consuption
Need some more information:-
1) Router type
2) Switch type
3) Location on the planet
4) How long the devices are going to be powered on?
5) Do you have a UPS?
6) Power supply - Hydro Electric, Solar, Fossil Fuel
7) Do you have any mice or rats with a wheel in their cage - to run the equipment if the power fails?
HTH>
Hi Baggiaraj,
1. Go to www.cisco.com.
2. In the upper right corner you will find a place where you can type in characters.
Type in the following:
power consumption guide
3. Click on "Go" to start the search function.
4. Select the document for the type of equipment you are interested in.
Cheers:
Istvan
117
