08-04-2006 04:01 PM - edited 02-21-2020 01:05 AM
My pix 506e got hit by lightning last night (and now I cant get ethernet0 to be up/up, just up/down) so I replace it with an ASA.
And the ASA wont do pppoe? Is that for real?
I read this thread:
but it wasnt entirely clear. When I enter the vpdn command on my ASA like I would on the pix I get an error msg that says its an unsupported command.
How can a pix support it but its replacement not? Am I just missing something? (likely) ;-)
thanks for any help
Bob
08-04-2006 04:26 PM
Hi Bob,
With Pix v7.0(x) or higher, there are few features no longer supported:
?PPPoE
?L2TP over IPSec
?PPTP
http://www.cisco.com/en/US/partner/products/ps6120/prod_release_note09186a008058cb4d.html#wp209006
So far, I have not seen any reason or alternate options/features for the above.
Rgds,
AK
08-04-2006 04:29 PM
Wow, thats just amazing. Tough to imagine why anyone would want a firewall with those features huh? Thank you for the link (and the bad news) ;-) Time to return it and get a $40 linksys.
Bob
08-04-2006 04:37 PM
Thats true that 7.0 doesnt support PPPoE, however 7.2(1) does support PPPoE. So I would suggest upgrading.
In regards to configuring it (if you didnt know), check out http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a008066ebe6.html
Good luck.
Glen
08-04-2006 05:21 PM
Glen, thank you a ton! That just might save my life :)
I just went to the download section (my login does allow me to download) but I couldnt even find the darn software for ASA. That will probably take me longer than the upgrade :)
thank you!
bob
08-04-2006 05:26 PM
Found it! Thanks guys, I appreciate it. Ill post here the outcome of PPPoE once I get it running.
Bob
11-06-2006 12:25 AM
Bob
was the pppoe config successful? can you post us the configs please?
Raj
11-06-2006 06:39 AM
Bob,
PPPoE is not supported when failover is configured on the security appliance, or in multiple context or transparent mode. PPPoE is only supported in single, routed mode, without failover.
For ASA 7.2 configuration guide for VPN and PPPoE:
I hope this helps.
Best Regards,
Troy McCarty
