PPTP and static NAT
Hi to all,
I have a question. I use a 2811 as a router and firewall (I configured it with SDM), my problem is with static NAT.
Witch port I have to NAT permit to use a VPN client PPTP like windowsXP client?
It's enougth to nat port 1723 to my server or I have to nat other tcp/udp port? My porblem is that I can not NAT all port to only one server.
There are some on-line document?
Thanks a lot.
Augusto
1 REPLY
Re: PPTP and static NAT
You're going to need to create two things:
NAT Translations
ip nat inside source static tcp 1.2.3.4 1723 interface fastethernet0/1 1723
replace 1.2.3.4 with your inside address ie VPN server and fastethernet0/1 with whatever your public interface is called.
You will also need to create and access-list to allow traffic to pass from outside-inside, ie Fastethernet0/1 "in"
access-list 120 permit tcp any 1.2.3.4 eq 1723
Apply this access-group to you outside interface "in".
Take care when removing enteries using the CLI with access list, you will delete the lot if you remove one! New enteries are appended to the bottom.
This is also possible through SDM and easier if you arnent to familiar with the CLI.
Create the NAT - under the nat tab, follow my example
Create access-list under firewall/ACL list tab.
Pls rate post that help
284
