Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
pptp connection
Dear all,
I have one unit cisco 2610 , i need to form pptp with windows 2k , what i need to use commnd vpdn-group xxxx , please give an advise whick IOS can site to my router DRAM 32M and flash have 16M, thank you .
Re: pptp connection
hope this link helps u out...
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_configuration_example09186a00801e51e2.shtml
for the support in ur current ios code keyin the commands related to the vpdn configs and check.
if its not working out then u need to check out the exact ios code which can fit into ur box with ur current hardware resources..
u need to check this tool for getting the reqd ios to run pptp..
http://tools.cisco.com/Support/Fusion/FusionHome.do
regds
Re: pptp connection
what is the feature name call ? for this vpdn configs , i try to use c2600-is56i-mz.120-28d.bin , no such command for vpdn , give an advise on IOS for my hardware c2600 , please help me , thank you
my hardware ver as below
sh ver
IOS (tm) C2600 Software (C2600-IO3-M), Version 12.2(7a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Thu 21-Feb-02 03:13 by pwade
Image text-base: 0x80008088, data-base: 0x809E77E8
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Router uptime is 1 minute
System image file is "flash:c2600-io3-mz.122-7a.bin"
cisco 2610 (MPC860) processor (revision 0x203) with 28672K/4096K bytes of memory.
Processor board ID JAD05310L7A (371552987)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Hall of Fame Super Gold
Re: pptp connection
I have not found a feature set with the features that you need that will run in 32 MB of memory. I found one realease in 12.1 code that only required 40MB. But most are like this one c2600-ik9s-mz.122-23f.bin which was the first version in the 12.2 releases to attain GD status and they require 48 MB of memory.
Rick
115
