PPTP Fails with Error 735
bill-anderson
I am having trouble connecting a Windows 2000 Professional SP2 machine via PPTP to a Cisco 3000 VPN Concentrator. I am successfully authenicated, and right after the computer displays "Registering Computer on Network" I get an error stating "TCP/IP CP reported error 735. The requested address was rejected by the server." I have all of my DUN connections set to use DHCP, so I don't understand why the error refers to a "requested address."
Thanks for everyone's help.
paqiu
In your VPN 3015 box, check following settings:
Configuration | System | Address Management | Assignment
Are you using address pool or DHCP ? ( I assume that you are using address pool , that is the simple way to make it working at first).
Then goto "Configuration | System | Address Management | Assignment"
define a address pool that, it should be working fine.
Best Regards,
awaheed
Hi Bill,
Also kindly make sure that you have selected the right checkbox under the Address Assignment. It goes from top to bottom on the list, so make sure you have only the one checked which you want to use or it may just be failing due to that aswell.
Hope this helps,
Aamir
