06-04-2003 05:24 AM - edited 02-21-2020 12:35 PM
Once I configured only PPTP connection,every PPTP client able to access the server.But after configure it to work with VPN client ,the problem arise with PPTP client unable to access the server and it fine with Csico VPN client.I'm running on PIX6.2Any idea is it because of the version?
06-05-2003 10:45 PM
You should be able to run both at the same time. Did you use the same IP address pool for both the PPTP and the IPSec users? If not, make sure your nat 0 access-list has two lines in it, one that specifies traffic from your internal network to the PPTP pool, and another line that says to the IPsec pool.
You can use the same IP address pool for both users then you'd only need the one line in the nat 0 ACL.
06-07-2003 05:31 AM
I'm using the same IP Pool.u know what is weired once I'm connected using PPTP thru VPN I get the local pool and were unable to ping to any of the LAN ws.But once I removed the Cisco VPN configuration on the PIX immediatelky there is reply from the ws.
