prefered format for PIX515E
Hello, I'm configuring a new PIX515E, and i'm a bit confused as to the proper fromat to use with regards to access-list/static command. I see 2 ways of doing things, and they both work... so if someone can explain which is the proper way, I'd appreciate it.
they are:
access-list ACL_OUT permit tcp any host xx.xx.xx.44 eq www
static (inside,outside) tcp xx.xx.xx.44 www 10.99.18.60 www netmask 255.255.255.255 0 0
access-group ACL_OUT in interface outside
OR
static (inside,outside) xx.xx.xx.44 10.99.18.60 netmask 255.255.255.255
Thanks!
William
  • Other Security Subjects
Gold
Re: prefered format for PIX515E
Hi Bill,
in 1st example is static NAT from xx.xx.xx.44 to 10.99.18.60 ONLY for http(www) traffic NO other traffic is NATed
in 2nd example is NATed ALL IP traffic
First example is considered to be more secure..
M.
Hope that helps rate if it does
great, thanks!
Silver
using the port number in the static command is typically used if you want to change port numbers. Ex to change port 80 to 8080. The second config you show would be standard way since you are not changing port numbers.
Hope this helps.
Steve
OH OH. now i'm more confused!
ok. maybe I should explain the setup?
IF I have my outside IP: 200.XX.20.20
and my inside subnet: 192.168.0.0
if I want to have a dedicated nat from outside to inside for web, which format would I need to use?
static (inside,outside) tcp xx.xx.xx.44 www 192.168.0.60 www netmask 255.255.255.255 0 0
OR
static (inside,outside) xx.xx.xx.44 192.168.0.60 netmask 255.255.255.255
now it makes sense to use the first: because i'm not changing ports, just sending the outside traffic to the inside IP...
I hope this clarifies things.
Will
181
