private address with VPN, NEED HELP!!
I want to configure an IPSec vpn upon Internet between two cisco routers :
2620 in the headQuarter, running a 12.0 version
2611 in the remote site, running a 12.0 version
my ethernet interfaces has a public address, and i have a private address for my networks.
Question:
can i configure a vpn between my two Ethernet interfaces as peer of VPN address, and keeping my private network address without using NAT???
thanks in advance.
  • Other Security Subjects
Re: private address with VPN, NEED HELP!!
I don't know exactly your scenario but why do you want to use NAT?. The original packet from your private network is encapsulated in the IPSEC tunnel and arrives to the remote netwok with the same private IP address that in the local address. The only think you must do is to add routes so that one network know that the other one is through the router 26XX.
124
