You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
privilege level Question
I'm using PIX 515E. I'd like the users with privilege level of 10 to be able to only run "show" commands. Is there a quick way of doing this or do I have to enter "privilege show level 10 command commandname" for every single command?
Thanx,
  • Other Security Subjects
1 REPLY
Re: privilege level Question
Yes you can move the commands to different privilege levels. Here is a sample configuration:
http://www.cisco.com/warp/public/110/pix_command.shtml
hope this helps,
-Nairi
86
