Problem Accessing PDM
Hi All,
Can someone help me resolving my problem; I've configured my PIX to be accessed through PDM from my subnet range and enabled the http server on the PIX. When trying to access the PIX through the browser, I'm prompted to the digital certificate and to enter the logon credentials but when entering the enable password and leaving the username blank (since the authentication type for the console is local), an HTTP 404 (the page not found) error message appears. I'm running PIX OS 6.3(5) and my client PC has Java Ver. 1.4.2. Does anybody have any idea of what could be the problem?
Haitham
Re: Problem Accessing PDM
Is PDM installed? you can verify by "show version"
you can try from a different pc. you can try the following
ca zeroize rsa
ca gen rsa key 512
ca save all
thanks
Nadeem
The PIX OS is 6.3(5) which comes with PDM installed by default, doesnt it?
Here's the output of show ver:
Cisco PIX Firewall Version 6.3(5)
Compiled on Thu 04-Aug-05 21:40 by morlee
PIX-Prim up 34 days 7 hours
Hardware: PIX-515E, 128 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : VAC (IRE2141 with 2048KB, HW:1.0, CGXROM:1.9, FW:6.
5)
0: ethernet0: address is 000c.abcd.7777, irq 10
1: ethernet1: address is 000c.abcd.7777, irq 11
2: ethernet2: address is 0002.abcd.7777, irq 5
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Physical Interfaces: 6
Maximum Interfaces: 10
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has an Unrestricted (UR) license.
Does this mean that PDM is not installed on my FW?
When trying to access the PDM from another machines, it doesnt work either.. Please advise.
Gold
the output of "sh ver" indicates that pdm is not installed.
you mentioned your machine has java plug-in v1.4.2 and it wouldn't work. i guess the you were attempting to connect to pdm v3.0(2). many pdm version doesn't support jave plug-in v1.4.2_08 and v1.5.0_02 or later
http://www.cisco.com/en/US/products/hw/vpndevc/ps4077/products_field_notice09186a008046c805.shtml
to resolve the issue, upgrade the pdm to the latest and it's v3.0(4). download a copy pdm requires special access right, e.g. a service agreement.
below is the guide for pdm installation:
http://www.cisco.com/en/US/products/sw/netmgtsw/ps2032/products_installation_guide_chapter09186a008017a421.html
276
