Problem accessing VPN3060 console
I have a unit of VPN3060. Fresh from the box, I can access it via console and put some configuration. No changes whatsoever on the access method, i.e disabling console access.
However, when I tried to access it via console again, it doesn't work. Access to other devices (router & switches) using the same console cable/com port works fine. The com port configuration is 9600-8-N-1 (standard for cisco router/switch/pix/vpn).
So far, I did not see any specific troubleshooting tips on this.
Appreciate any feedback.
AK
Re: Problem accessing VPN3060 console
Problem solved.
TQ
Gold
just wondering if you may share the resolution.
90
