Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problem add CAS in CAM NAC 4.7 SSL certificate
I have a problem with NAC 4.7, I cant add CAS in CAM, I imported the certified of www.perfigo.com and it doesnt work, i reboot the NAM and NAS and nothing.
Any suggest?
Best Regards
Re: Problem add CAS in CAM NAC 4.7 SSL certificate
Do this.
Go to the CAM GUI. Browse to CCA Manager -> SSL. Check the box marked CCA Manager Certificate and click on Export. Save this file as CAMCert.pem
Go to the CAS admin page by going to https://IP_ADDRESS_OF_CAS/admin Click on SSL. Check the box marked CCA Server Certificate and click Export. Save this file as CASCert.pem
On the CAS page, click on Trusted Certificate Authorities, click on Browse, and choose the CAMCert.pem. Click on Import
On the CAM page, click on CCA Manager -> SSL -> Trusted Certificate Authorities, click on Browse, and choose the CASCert.pem. Click on Import.
Now try to add one to the other.
HTH,
Faisal
Hello Faisal,
so, it is necesary install perfigoca.cer? or the exchange of certified must not be together perfigoca.cer?
Best Regards
Alvaro,
No, perfigo certs aren't necessary in 4.7
HTH,
Faisal
Thanks. This worked for me when I imported the whole certificate chain.
It is only necessary to import the CAM certs into the CAS and the CAS certs into the CAM under the trusted certificate authority, you no longer need the perfigo certs.
684
