problem for inside users accessing dmz server
I'm facing problem where inside users unable to get to the dmz server,try the vice versa as well,not working.PLs advise.My router is doing the nat for accesing net.
Saved
: Written by enable_15 at 04:09:29.685 UTC Fri Jan 1 1993
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security10
enable password xxxxxxxencrypted
passwd xxxxxxxxencrypted
hostname test
domain-name test
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
name 192.168.101.1 rosettanet
name 192.168.100.0 LAN
name 192.168.100.2 ERP
name 192.168.100.1 PDC
object-group service MSFileTransfer tcp-udp
description Services needed for MS File Sharing
port-object range 137 139
port-object eq echo
port-object eq 445
access-list inside_access_in permit tcp LAN x.x.x.0 any eq www
access-list inside_access_in permit icmp any any echo
access-list inside_access_in permit icmp any any echo-reply
access-list inside_access_in permit udp LAN x.x.x.0 any eq domain
access-list inside_access_in permit tcp host PDC host rosettanet object-group MS
FileTransfer
access-list inside_access_in permit tcp host ERP host rosettanet object-group MS
FileTransfer
access-list inside_access_in permit ip any any
access-list dmz_access_in permit tcp any any eq www
access-list dmz_access_in permit icmp any any echo-reply
access-list dmz_access_in permit tcp host rosettanet host PDC object-group MSFil
eTransfer
access-list dmz_access_in permit tcp host rosettanet host ERP object-group MSFil
eTransfer
access-list dmz_access_in permit udp any any eq domain
access-list dmz_access_in permit ip any any
access-list outside_access_in permit tcp any host 192.168.102.2 eq www
access-list outside_access_in permit icmp any any echo-reply
access-list outside_access_in permit tcp any host 192.168.102.3 eq 5900
access-list temp permit ip any any
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside 192.168.102.1 255.255.255.0
ip address inside 192.168.100.254 255.255.255.0
ip address dmz 192.168.101.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location PDC x.x.255.255 inside
pdm location rosettanet x.x.255.255 dmz
pdm location ERP x.x.255.255 inside
pdm location 192.168.102.254 255.255.255.255 outside
pdm logging emergencies 100
pdm history enable
arp timeout 14400
global (outside) 1 192.168.101.199 netmask x.x.255.0
global (dmz) 1 192.168.101.200-192.168.101.250 netmask 255.255.255.0
nat (inside) 1 LAN x.x.255.0 0 0
nat (dmz) 1 192.168.101.0 255.255.255.0 0 0
static (dmz,outside) 192.168.102.2 rosettanet netmask 255.255.255.255 0 0
static (inside,outside) 192.168.102.3 PDC netmask x.x.255.255 0 0
static (inside,dmz) rosettanet PDC netmask x.x.255.255 0 0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
access-group dmz_access_in in interface dmz
route outside 0.0.0.0 0.0.0.0 192.168.102.254 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http PDC x.x.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet 192.168.102.254 255.255.255.255 outside
telnet 0.0.0.0 0.0.0.0 outside
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:xxxxx
Re: problem for inside users accessing dmz server
What does the syslog say? Always, always, always turn on syslogging when you have connection problems thru the PIX, it'll tell you exactly what's going on.
logging on
logging buffer debug
Try a connection, then:
sho logg
What are the exact source and destination IP addresses involved here, and "get to the dmz server" with what protocol? Please provide as much information as you can in order for us to help you out.
Is my setting correct?
Can you answer my previous questions?
I would start with turning on "debug icmp trace" than ping from the DMZ to the inside and see where the pings are stopping. How come no routes to the inside? Is your DMZ set up properly on the router and switch?
104
