05-06-2006 07:19 AM - edited 02-21-2020 02:24 PM
Hi there.
I'm running Ubuntu "Dapper Drake" 6.06 Beta 2 and I'm unable to install the 4.7 version of the client :-(
I'm using GCC 3.4 as a compiler, not 4.0.
Here is the output from the install:
jjs@itchy:~/cisco_vpn/vpnclient$ ./vpn_install
Sorry, you need super user access to run this script.
jjs@itchy:~/cisco_vpn/vpnclient$ sudo ./vpn_install
Cisco Systems VPN Client Version 4.7.00 (0640) Linux Installer
Copyright (C) 1998-2005 Cisco Systems, Inc. All Rights Reserved.
By installing this product you agree that you have read the
license.txt file (The VPN Client license) and will comply with
its terms.
Directory where binaries will be installed [/usr/local/bin]
Automatically start the VPN service at boot time [yes]
In order to build the VPN kernel module, you must have the
kernel headers for the version of the kernel you are running.
Directory containing linux kernel source code [/lib/modules/2.6.15-21-686/build]
* Binaries will be installed in "/usr/local/bin".
* Modules will be installed in "/lib/modules/2.6.15-21-686/CiscoVPN".
* The VPN service will be started AUTOMATICALLY at boot time.
* Kernel source from "/lib/modules/2.6.15-21-686/build" will be used to build the module.
Is the above correct [y]
Making module
make -C /lib/modules/2.6.15-21-686/build SUBDIRS=/home/jjs/cisco_vpn/vpnclient modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.15-21-686'
CC [M] /home/jjs/cisco_vpn/vpnclient/linuxcniapi.o
/home/jjs/cisco_vpn/vpnclient/linuxcniapi.c: In function `CniInjectReceive':
/home/jjs/cisco_vpn/vpnclient/linuxcniapi.c:292: error: structure has no member named `stamp'
/home/jjs/cisco_vpn/vpnclient/linuxcniapi.c: In function `CniInjectSend':
/home/jjs/cisco_vpn/vpnclient/linuxcniapi.c:432: error: structure has no member named `stamp'
make[2]: *** [/home/jjs/cisco_vpn/vpnclient/linuxcniapi.o] Error 1
make[1]: *** [_module_/home/jjs/cisco_vpn/vpnclient] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.15-21-686'
make: *** [default] Error 2
Failed to make module "cisco_ipsec.ko".
And here's my gcc version info:
jjs@itchy:~$ gcc -v
Reading specs from /usr/lib/gcc/i486-linux-gnu/3.4.6/specs
Configured with: ../src/configure -v --enable-languages=c,c++,f77,pascal --prefix=/usr --libexecdir=/usr/lib --with-gxx-include-dir=/usr/include/c++/3.4 --enable-shared --with-system-zlib --enable-nls --without-included-gettext --program-suffix=-3.4 --enable-__cxa_atexit --enable-clocale=gnu --enable-libstdcxx-debug --with-tune=pentium4 i486-linux-gnu
Thread model: posix
gcc version 3.4.6 (Ubuntu 3.4.6-1ubuntu2)
Anyone help will be very welcome!
05-08-2006 06:58 AM
infact even i tried with ubuntu, it didn't work out, but when i tried in Redhat Linux it works perfectly. i think cisco vpn client is specially designed to run on redhat linux.same case when i tried installing the cisco vpn client in POWER MAC, it works fine, but not on INTEL MAC.
06-06-2006 05:34 AM
Firstly, Dapper compiles its kernels with GCC 4, so that's what you need to use. Also, you need to apply a patch, which I'll upload. I found it on the Web somewhere, so use at your own risk; it works for me. To apply it, issue while in the vpnclient directory:
patch < vpnclient-4.7-patch
06-06-2006 05:38 AM
06-06-2006 05:42 AM
In case anyone needs this after the attachment expires in June 2007, the original is at http://www.redhat.com/archives/rhl-list/2005-November/msg02667.html
