Problem installing VPN client 3.6.1 on Win2k
ERIK ELMER
Have installed the 3.6.1 client om several Win2k PCs. No,
problem at all. However I cannot get in working on my own PC !
The DNE installation fails. No error message during installation.
I get something such as "necessary subsystem not available" when
starting the VPN client. DNE is also not present the "LAN properties"
dialog box. I have tried following the instructions published for
manual uninstallation of the 3.5.1 client. Have also search the entire
regedit for "dne" and "vpn" as well as for files related. Can´t find anything
left, yet installation fails. I have tried both versions of the installation.
Would appreciate any advance. Can I may be try the latest 3.5.x client ?
edadios
The latest 3.6.2 client is now available from CCO. If you have a login and 3des access, go here: http://www.cisco.com/cgi-bin/tablebuild.pl/vpnclient-3des . Other 3.5 clients are also on the same page.
Otherwise, check what is different between your pc and once that get the client installed, such as network card, other vpn installed, service pack version, other apps .....
Good Luck....
marwahs
Hi, I have the same problem in XP. Found this at Bug Tool:
CSCdy58208 Bug Details
Release Notes
Symptom: When the vpn client 3.6.1 (Microsoft Installer) is installed on the XP we get a error
Error: Dneinst execution error while installing DNE, returncode - 2146500093
When we click on OK - it continues with the installation and then we get a Missing vpn subsystems error after the system is rebooted and we try to start the vpnclient
We do not see this error when we use the InstallShield version of the client , but on reboot of the PC , the error - Missing VPN subsystem comes up when we try to start the vpn client
Workaround: There is no known workaround at this time
Hello:
I had done a reinstall of the VPN client and experienced the same thing. I think this fix will work for anyone, particularly those users who had previous VPN client installations.
The problem seems to lie in the following registry key (folder):
HKEY_LOCAL_MACHINE\SOFTWARE\DeterministicNetworks
On a reinstall or uninstall, that key folder is left, but the values are changed and, oddly enough, you cannot delete or edit the key or its folders via RegEdit. It would appear the key gets totally munged somehow in the process.
If you go to winfiles.com or some other shareware repository you can search on "registry" and come up with any number of utilities for restoring your Registry to a previous copy. The one I picked allowed me to restore the registry to the way it was just previous to installing the client.
Once I had the registry restored I reinstalled the software and it worked flawlessly. The visual difference was this:
1) Hardware Installation Warning for Unsigned Drivers - if you see this and have to hit continue a few times, it will work.
2) If you don't see it, your installation is corrupted.
Mike
