kyd
Problem with ASDM
I have problem in connecting to the PIX firewall via the ASDM interface. Everytime I try to connect, i have the following error message: remote host closed connection during handshake. I am sure the Ip address and passwork I put in is right. the version of my PIX is 7.0(4) and ASDM version is 504. Please help. Thanks
Re: Problem with ASDM
Can you paste your configuratin which reflects to ASDM and your PC Ip address where you are trying to connect?
Try re-generate the RSA keys with the command:
crypto key generate rsa
For more info:
http://www.cisco.com/univercd/cc/td/doc/product/multisec/asa_sw/v_70/cref_txt/c.htm
Hope it helps
Franco Zamora
kyd
I have try to regenerate the key but it still have the same problem. My configuration regarding the ASDM is as follow:
http server enable
http x.x.x.x 255.255.255.255 inside
I can ping / telnet / tftp from that PC so that I'm sure they talk to each other.
Please help me to resolve this problem. Thanks
Did you added path
asdm image flash:/asdm-501.bin
Laptom
150
