problem with CBAC !
Hi all,
I'm testing IOS fw so in a lab envirement i connected 2 host through a router(IOSfw) in such way:
(internalhost)----------[e0/0](IOSfw)[s1/0]-----------(external host)
It seems that "ip inspect" has no effect and acl 101 is still blocking traffic from external zone
Here is ACL logs:
*Mar 1 01:16:38.730: %SEC-6-IPACCESSLOGP: list 101 denied tcp 192.168.0.1(23) (
Serial0/0 ) -> 10.0.0.1(57410), 1 packet
*Mar 1 01:17:06.595: %SEC-6-IPACCESSLOGP: list 100 permitted tcp 10.0.0.1(0) (E
thernet0/0 0007.ebff.35a0) -> 192.168.0.1(0), 4 packets
*Mar 1 01:17:06.595: %SEC-6-IPACCESSLOGP: list 102 permitted tcp 10.0.0.1(0) (E
ping the external host is successful as i'm allowing it through acl 101
Any idea? think you in advance
IOSFW config
version 12.3
hostname IOS-FW
boot-start-marker
boot-end-marker
logging monitor notifications
no aaa new-model
ip subnet-zero
ip inspect audit-trail
ip inspect udp idle-time 1800
ip inspect dns-timeout 7
ip inspect tcp idle-time 14400
ip inspect name http_out http alert on audit-trail on
ip inspect name http_out tcp alert on audit-trail on
ip inspect name http_out udp alert on audit-trail on
ip inspect name http_out icmp alert on audit-trail on
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0/0
ip address 10.0.0.2 255.255.255.0
ip access-group 100 in
ip access-group 101 out
half-duplex
interface Serial0/0
ip address 192.168.0.2 255.255.255.0
ip access-group 102 out
ip classless
ip http server
no ip http secure-server
logging facility local4
logging source-interface Ethernet0/0
logging 10.0.0.3
access-list 100 permit ip host 10.0.0.3 any
access-list 100 permit ip any host 10.0.0.3
access-list 100 permit icmp host 10.0.0.1 host 192.168.0.1 log-input
access-list 100 permit tcp host 10.0.0.1 host 192.168.0.1 log-input
access-list 101 permit ip host 10.0.0.3 any log-input
access-list 101 permit ip any host 10.0.0.3 log-input
access-list 101 permit icmp any any echo-reply log-input
access-list 101 permit icmp any any time-exceeded log-input
access-list 101 permit icmp any any traceroute log-input
access-list 101 permit icmp any any unreachable log-input
access-list 101 permit icmp any any packet-too-big log-input
access-list 101 deny tcp any any log-input
access-list 101 deny udp any any log-input
access-list 101 deny ip any any log-input
access-list 102 permit ip host 10.0.0.3 any
access-list 102 permit ip any host 10.0.0.3
access-list 102 permit icmp host 10.0.0.1 host 192.168.0.1 log-input
access-list 102 permit tcp host 10.0.0.1 host 192.168.0.1 log-input
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end
IOS-FW#
Re: problem with CBAC !
In the ACL 101, it seems that the tcp, udp & IP, e.g telnet TCP 23 (based on your log) was blocked.
Maybe you need to test it again by only permitting TCP, and maintain the remaining deny statements (for UDP & IP). BTW, the statement 'deny IP' is probably not necessary as you already specify TCP and UDP in the previous line. IP covers both TCP and UDP.
Rgds,
AK
Even though IP inspect is enabled .. it will not work util you applied it ot the interfaces. ip inspect < options> from the interface mode. Yu cn check this link for some info
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1831/products_command_reference_chapter09186a00800d9806.html#wp1017470
Sorry I posted the configuration before enabling "ip inspect" on the external interface and still didn't work even with it.
Please see the attached doco I have together for you .. let me know how you go and rate it is you find it useful
88
