problem with IPSEC through zyxel 650R-31 to PIX 506
Hello
I have a setup with a Zyxel 650R-31 connected to an ADSL coonection. behind the Zyxel I have a Cisco PIX 506E connected. I have setup the zyxel to forward all ports to the PIX IP. The port forwarding works fine (WWW, FTP, SMTP and so on). PPTP to the PIX also works fine, but when i use Cisco VPN client (IPSEC) to make the connection, something goes wrong. I can see that the user gets correctly authenticated in the system log on the RADIUS server. What happens is that the VPN client "hangs" at "Securing communications channel" and then gives the error message: "Secure VPN connection terminated locally by the client. Reason 412: The remote peer is no longer responding".
What could be the problem ???
Here is some of the config output og the PIX:
domain-name vinduesland.local
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
no fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list outside permit tcp any host 10.0.0.2 eq smtp
access-list 101 permit ip 192.168.3.0 255.255.255.0 192.168.99.0 255.255.255.0
pager lines 24
logging on
logging trap notifications
logging facility 16
logging host inside 192.168.3.115
mtu outside 1500
mtu inside 1500
ip address outside 10.0.0.2 255.255.255.0
ip address inside 192.168.3.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool vpnpool 192.168.99.1-192.168.99.100
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface smtp 192.168.3.11 smtp netmask 255.255.255.255 0 0
access-group outside in interface outside
route outside 0.0.0.0 0.0.0.0 10.0.0.1 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa-server partnerauth protocol radius
aaa-server partnerauth max-failed-attempts 3
aaa-server partnerauth deadtime 10
aaa-server partnerauth (inside) host 192.168.3.10 ******** timeout 5
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map mymap client authentication partnerauth
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup vinduesland address-pool vpnpool
vpngroup vinduesland dns-server 192.168.3.10
vpngroup vinduesland default-domain vinduesland.local
vpngroup vinduesland split-tunnel 101
vpngroup vinduesland idle-time 1800
vpngroup vinduesland password ********
telnet 192.168.3.0 255.255.255.0 inside
telnet timeout 5
ssh 192.168.3.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
terminal width 80
1 REPLY
Gold
Re: problem with IPSEC through zyxel 650R-31 to PIX 506
just a quick comment.
in order to permit ipsec traffic, esp is required and it's ip 50. port forwarding wouldn't be able to cope with ip, only tcp or udp.
524
