problem with nat + vpn
I have a problem with my vpn. I have two client that have the same subnet. I make a draw to explain that because my english is bad :
http://kenshin-est.chez.tiscali.fr
I proceed like that : i define "virtual" ip (40.0.1.0, 20.0.1.0, 30.0.1.0) to separe the same subnet. I create the vpn between the "virtual" address. So i must nat the real address. I have a problem with that. I use the command static (static (inside,outside) 20.0.1.0 10.0.10) so the address is well change. But i have a new problem : the address is nat into 20.0.1.0 so i can't go to the web because there is no nat to change my private ip into a public ip.
To sum up i dont know how i create "different" nat if i go to the vpn i will nat into 20.0.1.0 and if i go the web i'll nat into my public ip. I don't know if it possible.
Thx u very much.
regards,
Kenshin
Bronze
Re: problem with nat + vpn
Hi Kenshin ,
As far as my knowledge goes, this cannot be done.
Thx u anyway :)
84
