04-03-2003 05:39 AM - edited 03-09-2019 02:45 AM
I have a problem with my pix. The situation :
i must nat if the packets go to my vpn.
i must nat if the packets go to the web.
So i must define one rules of nat for each case. But i don"t know how says that to my pix. I think used an acl (same as with nat 0) but pix doesn't accept the commande : nat (inside) 10 access-list 101 . So i have no idea (i had try the command static but if i used it i can access to my vpn but no to the web with my public ip). I haven't find any documentation about this problem ;(
Thx you in advance
Kenshin
04-03-2003 06:40 PM
You can't NAT to a different address based on an access-list in the PIX. Sorry.
04-03-2003 10:34 PM
Thank you very much.
