Problem With OWA Publishing
I have a Cisco Pix 515-E with ios 7.0(4). I have a exchange server with OWA behind inside interface with 80 tcp port open, login process is successfull but when try to list my messagess, dont appear anything. Whats Problem ?
Re: Problem With OWA Publishing
First and foremost, I recommend that you provision OWA via SSL (HTTPS/443).
Anyway....
I have OWA 2000 and 2003 running at sites with 7.0(4) without problems. Just in case, try disabling inspect for http. Also make sure there is not an http reverse proxy in front of OWA, or any filtering on your point of remote access. HTTP proxies break WebDAV easily.
Thnaks for your answer. One more question, when you say disable inspect for http in 7.0(4), what specific parameter have i disable, i appreciatte so much the command to do this.
In 7.0 it's a little more complicated than doing just a no fixup. You must modify the inspection class for the default global policy map.
firewall# conf t
firewall(config)# policy-map global_policy
firewall(config-pmap)# class inspection_default
firewall(config-pmap-c)# no inspect http
166
