Problem with routing traffic through IPSEC connection from VPN Client to 30
I'm having a small issue with a new VPN 3015 concentrator. I can connect to the 3015 with the Cisco VPN client 3.5.x on a windows sysstem and successfully establish a connection. I can't access anything after that. Any suggestions/fixes/How-to's to look at would be appreciated.
  • Other Security Subjects
1 REPLY
Re: Problem with routing traffic through IPSEC connection from V
Check if your network card has an ip address on the same subnet as the what
the vpn concentrator is assigning to its clients, or
if you are behind a NAT device, then enable on the conc and client the IPSec thru UDP. If you are behind a PAT device, use IPSec thru TCP.
90
