Community Member
Problem with Static and Dynamic NAT on ASA5510
i am using ASA5510 for my network.i have configured static and Dynamic NAT.static NAt working fine.Dynamic NAT pool have a 10 public Ip Addresses.but inside users cannot able to access internet.
Error:
Port map Translation failed.
but this dynamic NAT changed to PAT .its working.
Please help me to configure Dynamic NAT
regs
S.Mohana sundaram
Gold
Re: Problem with Static and Dynamic NAT on ASA5510
can you post your nat and global commands that you have configured please. is the dynamic nat pool in the same network range as the IP address of your outside interface of the ASA?
Community Member
yes.my global pool same as outside Ip range
my puplic ip is x.x.x.0/27
the above subnet have 30 Ip's active the range is x.x.x.1 to x.x.x.30,x.x.x.31 is broadcast.
global (outside) 1 x.x.x.15-x.x.x.29
nat (inside) 1 172.16.0.0 255.255.0.0
static (DMZ,outside) x.x.x.4 10.1.1.2 netmask 255.255.255.255
static (DMZ,outside) x.x.x.5 10.1.1.3 netmask 255.255.255.255
static (DMZ,outside) x.x.x.6 10.1.1.4 netmask 255.255.255.255
static (DMZ,outside) x.x.x.7 10.1.1.5 netmask 255.255.255.255
static (DMZ,outside) x.x.x.8 10.1.1.6 netmask 255.255.255.255
Thanks.
regs
S.Mohana sundaram
Gold
with this configuration, what is the output of "show xlate".
also, have you tried something like:
global (outside) 1 x.x.x.15-x.x.x.28
global (outside) 1 x.x.x.29
167
