Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
problem with static to dynamic connections in VPN
hi,
i try to configure a pix 515 to accept dynamic connection from remote clients and remote cisco ios routers (with dynamic ip).
i have no problem with the clients but i can't establish a tunnel with the routers.
here is my configuration file on the pix :
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password jLM8v3IOUGCnCDWR encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname Sabetpix
domain-name Sabet.fr
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list sabet1_splitTunnelAcl permit ip 192.168.0.0 255.255.255.0 any
access-list inside_outbound_nat0_acl permit ip 192.168.0.0 255.255.255.0 192.168.0.192 255.255.255.224
access-list inside_outbound_nat0_acl permit ip 192.168.0.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list inside_outbound_nat0_acl permit ip 192.168.0.0 255.255.255.0 192.168.20.0 255.255.255.0
access-list outside_cryptomap_dyn_20 permit ip any 192.168.0.192 255.255.255.224
access-list sabet2_splitTunnelAcl permit ip 192.168.0.0 255.255.255.0 any
access-list outside_cryptomap_dyn_40 permit ip any 192.168.0.192 255.255.255.224
access-list outside_cryptomap_dyn_60 permit ip any 192.168.0.192 255.255.255.224
access-list outside_cryptomap_dyn_80 permit ip 192.168.0.0 255.255.255.0 sabet0 255.255.255.0
access-list outside_cryptomap_dyn_90 permit ip 192.168.0.0 255.255.255.0 192.168.10.0 255.255.255.0
pager lines 24
logging on
logging console notifications
logging monitor notifications
interface ethernet0 auto
interface ethernet1 auto
mtu outside 1500
mtu inside 1500
ip address outside pppoe setroute
ip address inside 192.168.0.200 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool remotevpn1 192.168.0.205-192.168.0.210
no failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
pdm location 192.168.0.1 255.255.255.255 inside
pdm location 192.168.10.0 255.255.255.0 outside
pdm location sabet0 255.255.255.0 outside
pdm location 192.168.0.0 255.255.255.0 outside
pdm history enable
arp timeout 14400
global (outside) 10 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 10 0.0.0.0 0.0.0.0 0 0
conduit permit icmp any any
conduit permit tcp any any
conduit permit udp any any
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.0.0 255.255.255.0 outside
http 192.168.10.0 255.255.255.0 outside
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-DES-MD5
crypto dynamic-map outside_dyn_map 40 match address outside_cryptomap_dyn_40
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-DES-MD5
crypto dynamic-map outside_dyn_map 60 match address outside_cryptomap_dyn_60
crypto dynamic-map outside_dyn_map 60 set transform-set ESP-DES-MD5
crypto dynamic-map outside_dyn_map 80 match address outside_cryptomap_dyn_80
crypto dynamic-map outside_dyn_map 80 set transform-set ESP-DES-SHA
crypto dynamic-map outside_dyn_map 90 match address outside_cryptomap_dyn_90
crypto dynamic-map outside_dyn_map 90 set transform-set ESP-DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
isakmp policy 90 authentication pre-share
isakmp policy 90 encryption des
isakmp policy 90 hash md5
isakmp policy 90 group 2
isakmp policy 90 lifetime 6400
vpngroup sabet1 address-pool remotevpn1
vpngroup sabet1 wins-server 192.168.0.1
vpngroup sabet1 default-domain Sabet.fr
vpngroup sabet1 split-tunnel sabet1_splitTunnelAcl
vpngroup sabet1 idle-time 1800
vpngroup sabet1 password ********
vpngroup sabet2 address-pool remotevpn1
vpngroup sabet2 wins-server 192.168.0.1
vpngroup sabet2 default-domain Sabet.fr
vpngroup sabet2 split-tunnel sabet2_splitTunnelAcl
vpngroup sabet2 idle-time 1800
vpngroup sabet2 password ********
vpngroup sabet3 address-pool remotevpn1
vpngroup sabet3 wins-server 192.168.0.1
vpngroup sabet3 default-domain sabet.fr
vpngroup sabet3 idle-time 1800
vpngroup sabet3 password ********
telnet 192.168.10.0 255.255.255.0 outside
telnet 192.168.0.0 255.255.255.0 outside
telnet 192.168.0.0 255.255.255.0 inside
telnet timeout 5
ssh 192.168.0.0 255.255.255.0 outside
ssh timeout 5
vpdn group pppoe_group request dialout pppoe
vpdn group pppoe_group localname fti/ebt6t2k
vpdn group pppoe_group ppp authentication chap
vpdn username fti/ebt6t2k password *********
vpdn username sabet password *********
dhcpd domain sabet.fr
username sabet password pnDLqQIbA4bEoSxg encrypted privilege 15
terminal width 80
Cryptochecksum:e47cbc2c347e3834312c25df974b56ef
: end
help,
thanks !
Bronze
Re: problem with static to dynamic connections in VPN
Can you enable:
debug cry isa
debug cry ip
These debugs are needed to troubleshoot the problem
Jazib
hi, i resolve the problem by enabling also ipsec keepalive on the pix.
keepalive was enable on the router but not on the pix.
so i add the command : "isakmp keepalive 60 60".
thanks for your interest about this question!
91
