09-11-2006 06:40 AM - edited 03-09-2019 04:09 PM
dear all,
we had 3 pix firewall installed by our customer: 2 515e and 1 506e
i make the upgrade on the two pixs 515e to 7.2(1) now when i make a
write net the config doesent upload to the tftp server. with the pix 506e
version 6.3(5) works the upload to the same tftp server fine.its a bug in the new version?
befor upgrade to 7.2(1) does work the tftp upload!
here the output:
pix# wr net
Building configuration...
Cryptochecksum: xxxx
%Error writing tftp://192.168.40.10/pix.cfg;int=inside
(Timed out attempting to connect)
[FAILED]
pix-hard#
thanks for any help
nik
09-11-2006 08:20 AM
Check your tftp server statement. I am expecting to look something like:
tftp-server inside 192.168.40.10 pix.cfg
09-11-2006 11:33 AM
hello,
yes the statement is: tftp-server inside 192.168.40.10 pix.cfg its make also a file with the name pix.cfg in the tftp server upload/download directory buth the file is empty! i have installed a 3CDaemon tftp server.
09-13-2006 04:09 AM
Try it with disabling the inspection rule for TFTP, that helped in my case (but the config was needed on the FWSM after upgrading from 2.3 to 3.1).
Patrick
09-14-2006 09:55 AM
Hello Patrick
Thanks for your answer. i turned off the default inspection rule for tftp, but the problem stay the same. anyway thanks...
09-16-2006 10:30 AM
Hi Nik,
Use the command (copy flash: tftp:) and when it asks you for the file name type the name of the file which you will find when you type the command (show flash)
Please rate if this helps,
Best regards,
