Problem with Tftp and Asdm install
Greetings,
When I tried to install asdm-502.bin to my newly upgraded box to 7.02 I get and the following error (This error is not new to me. It happened also when I tried to upgrade from Pix635 to Pix702 from Monitor,. Is there a fix. Thanks.
pix# copy tftp://192.168.1.20 flash:/asdm-502.bin
Address or name of remote host [192.168.1.20 ]?
Source filename [asdm-502.bin]?
Destination filename [asdm-502.bin]?
Accessing tftp://192.168.1.20 /asdm-502.bin...
%Error opening tftp://192.168.1.20 /asdm-502.bin (No such device)
When I tried to ping the 192.168.1.20. I get no success.
Gold
Re: Problem with Tftp and Asdm install
well you mentioned you can't ping 192.168.1.20 from the pix, so it means the network connectivity is not there. either they are not connected physically or the ip are not right. another possiblity is that the .20 host has software firewall installed, which blocks all inbound traffic.
jackko,
Thanks for taking the time.
About connectivity. I was able to install 7.02 from Monitor with no problem.
This problem is somehow related to installing 7.02. Because after I installed the 7.02, I couldn't tftp from Monitor or from #.
I replaced my .20 with an old 98 machine (no firewall) = still the same.
I did a wr erase and reloaded 635 instead of 7.02, no problems with tftp either from Monitor or #!!!
Gold
you mentioned "Because after I installed the 7.02, I couldn't tftp from Monitor or from #." just wondering if you were trying to downgrade from v7. if so, the procedure is a little bit different. e.g. you need to use the command "downgrade".
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804708d8.shtml#t6
Yes, you are right the procedure is different for downgrading, that is if you have the old file in the flash by using (pixfirewall# downgrade flash:/image_old.bin).
Otherwise you will have to dig it with tftp. I am aware of it because I run into it and had to take another shortcut since before I upgraded to 702 I deleted my flash :).
But my problem showed up after I installed the 7.02 and wanted to install the Asdm-502.bin.
Gold
please excuse me for misunderstanding the issue.
i just did the install from the lab and it works fine. assuming you've verified the network connectivty between the pix and the tftp server, as well as the tftp services availability, then there maybe a bug with the os. i guess the only way is to open a case with cisco tac.
Jakko,
Today was my lucky day.
1- I deleted the flash on both
2- I installed from Monitor the Pix635.bin, then the 302 pdm from the # on both.
3- did my config and synched w/failover
4-I shut down my primary
5-On my secondary (the one that wouldn't connect from Monitor or # after upgrade to 702) I Did a "copy tftp flash" to upgrade from pix635 to pix702. It went fine
3-Reloaded, then did a "copy tftp flash" to upgrade the pdm to asdm-502 and it worked at my surprise.
4-I switched it off and did the same thing to my Primary. And no problem there as I was anticipating.
So I am all up. Asdm502 interface is much better.
Thanks for the time.
If you are facing issues with PIX OS or PDM / ASDM upgrades via TFTP and at the same time if you have Internet connectivity from the PIX, you can use the following command to upgrade your PIX via HTTP:
PIX OS Upgrade:
pixfirewall(config)#copy http://:@198.133.219.27/cisco/ciscosecure/pix/.bin flash
PDM Upgrade:
pixfirewall(config)#copy http://:@198.133.219.27/cisco/ciscosecure/pix/.bin flash:pdm
ASDM Upgrade:
Note: For this procedure to work you need a valid CCO ID with software download permission.
Cheers...
Prashant Chauhan.
That's great.
I'll keep that in mind.
Thanks.
274
