Problem With VPN Client Config on 857W
Hy,
I arrive to establish the vpn but I can't establish the communication.
hostname A
logging buffered 51200 debugging
logging console critical
enable secret xxxx
username user password xxxx
username user1 password xxxx
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network sdm_vpn_group_ml_1 local
aaa session-id common
ip subnet-zero
no ip source-route
ip dhcp pool sdm-pool1
import all
network 192.x.x.0 255.255.255.0
default-router 192.168.0.254
dns-server 80.10.x.x.10.246.129
ip cef
ip tcp synwait-time 10
no ip bootp server
no ip domain lookup
ip domain name domain.net
ip name-server 193.x.x.3
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group Client-Vpn
key passw0rd
dns 193.x.x.3 194.6.128.4
pool SDM_POOL_1
max-users 5
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SDM_DYNMAP_1 1
set transform-set ESP-3DES-SHA
reverse-route
crypto map SDM_CMAP_1 client authentication list sdm_vpn_xauth_ml_1
crypto map SDM_CMAP_1 isakmp authorization list sdm_vpn_group_ml_1
crypto map SDM_CMAP_1 client configuration address respond
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
pvc 8/35
pppoe-client dial-pool-number 1
interface FastEthernet0
no ip address
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface Dialer0
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname fti
ppp chap password xxxx
ppp pap sent-username fti password xxxx
interface BVI1
description $ES_LAN$
ip address 192.168.x.x.255.255.0
ip nat inside
ip local pool SDM_POOL_1 10.0.0.1 10.0.0.20
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.x.x.0 0.0.0.255
access-list 101 permit ip 10.0.0.0 0.0.0.255 any
access-list 101 permit udp any any eq non500-isakmp
access-list 101 permit udp any any eq isakmp
access-list 101 permit esp any any
access-list 101 permit ip any any
access-list 102 remark SDM_ACL Category=2
access-list 102 deny ip any 10.0.0.0 0.0.0.255
access-list 102 permit ip 192.168.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
no cdp run
route-map SDM_RMAP_1 permit 1
match ip address 102
control-plane
bridge 1 protocol ieee
bridge 1 route ip
1 REPLY
Re: Problem With VPN Client Config on 857W
i do not see a "set peer" under your crypto map, if that is the question you are asking
88
