Problem with VPN Client
Hi ,
I have installed VPN client 3.1 on Windows XP Machine, i am able to successfully able to login to VPN. But after few minutes the connectiopn breaks. i get the following error
"Your IPSec connection has been terminated"
Please help.
Re: Problem with VPN Client
Is there any useful output from the VPNClient Log Viewer or the device you are connecting to? Are you passing traffic over the connection before it terminates or is the tunnel sitting idle?
Gareth
Yes i am passing continious traffic over the tunnel
after 1-2 Minutes the connection get terminated. I have not faced any problem with NT or 2000 its it a problem with XP ?
Where do i check the logs ?
93
